G550 22 rims
You can use this site to compare between sizes. 305/40 R22 is pretty close to the stock 295/40 size. Is the tire you want available in either size?
https://tiresize.com/tiresizes/295-40R22.htm
Did you order OEM wheels? There’s an offset calculator on the same site, if you want to get the full comparison to your current setup:
https://tiresize.com/wheel-offset-calculator/
