Dash trim & push start button replacement help
The previous owner of my 2020 G350d had it wrapped, including the interior trim pieces. In the process I assume they tried to pry out the engine start button and the trim pieces that sweeps left to right incorporating that button, using a screwdriver or something and they've damaged both the start button and the brushed aluminium look trim.
I’ve sourced the new button easily enough and will probably look to repair the trim pieces but will decide on that once off the car.
So my question, how does these come out, I read that mostly the other trim pieces pry out with removal tools but this piece isnt as straight forward, has anyone done it or have instructions please?
Carl
I might see how much my local dealer will charge to replace the trim and the start stop button.
Thanks for the info on removing
Carl
Are there any tips to removing the AC vent, last time I did one on an GLS I recall having mixed results, some came out great others seemed like I was about to drag it apart, as if I was pulling in different places on the inner housing or something. The G has very different looking vents aswell.
After that is it simple trim clips with pull force?
