G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
2019 G63 Window Seal Rattle/ creaking
Old Aug 30, 2025 | 11:32 PM
Carbug2's Avatar
1984 300SD Manual, 1985 420SEL Euro, 2013 Viper GTS, 2016 Dodge Charger Hellcat, 2017 Ram 2500
Hello!
I recently purchased a 2019 G63. Clean California truck. 27k miles. The windows make a creaking/ rattle noise over 60 MPH. It's almost like crackling/ static. The doors/ door seals seem to creak as well. I lubricated the window seals and it didn't make too much of a difference. Any suggestions would be appreciated!
Thank you!
Old Aug 31, 2025 | 08:00 PM
Alexie's Avatar
Originally Posted by Carbug2
Hello!
Thank you!
That's a common issue on the G63. The creaking is usually from the door seals. Try a proper silicone-based lubricant like Gummi Pflege, not just any lubricant. For the window rattle at speed, the window regulator or mounting may be loose; that likely requires a dealer or shop to diagnose and adjust the mechanism.
Old Aug 31, 2025 | 08:08 PM
sweet63's Avatar
2024 G 63, 2015 Ferrari 458 Speciale
I've had good luck with 3M Silicone Paste on rubber parts that occasionally creak or squeak
https://a.co/d/9OsXnXN
