G Class (W465/W463A) W463 Produced 2019-2024: G550, G63 AMG W465 Produced 2025-
G63 Fully Disable Traction Control
Old Oct 5, 2025 | 05:27 AM
DukeL's Avatar
2021 G63 2022 EQS 450+
How do I fully disable traction control?
Holding the TC button for 3 seconds, the screen shows traction all the way off, but it still cuts power significantly and I can’t break traction at all.
Yes it’s a luxury car, not meant to break traction, but I paid for it so I should be able to play with it, especially since it’s the AMG 63 model with a tremendous V8.
It’s impossible to steer with dyno mode and headlights + ABS are turned off too. Turning on center diff lock is obviously not smart on road.
Old Oct 5, 2025 | 07:48 PM
hard top's Avatar
2012 Land Rover LR4 5.0L V8 LUX HD
Old Oct 5, 2025 | 08:03 PM
Alexie's Avatar
You can't fully disable it through the normal buttons. The "ESP OFF" you get by holding the button still leaves a significant safety net, especially on the newer models.
The only true way to get everything off is through a specialized tuning tool or software that can code out the systems, but that's a whole different level of risk. Mercedes doesn't give you a true "off" switch because the stability systems are deeply integrated to prevent you from rolling a very tall, heavy vehicle.
