Designo Night Black Matte (color question)
Does it need special care? Do you need to wipe out bird drops and remove smashed insects within 10 minutes or the paint is "gone"?
This is how Mercedes describes their magno finishes:
Also, scroll down and read the comments in the link below. Good infohttp://www.luxury4play.com/detailing...-products.html
The bold info and steps below were boosted from another web site (luxury4play.com), so its not my writing, but it appears to be solid info, so read on but do your research on the swissvax product.
Matte or Satin Finish Paint - if polished with traditional polishes the finish will become less matte and glossier over time; do not wet-sand or use conventional wax or use an automatic car wash that uses hot wax in the final rinse, as the flattening agents that cause the matte appearance will become ‘levelled ‘The textured finish is accomplished by a diffused 30 degree reflection and are retained very close to the clear coat surface. By levelling the surface the light will be reflected evenly and result in a ‘shine’.
Use a machine polisher and an ultra soft, zero abrasive cut (Lake County CCS Concourse Gold (100 PPI) foam pad) with a mild chemical paint cleaner (Zaino Z-AIO - All in One) it will remove surface marring and leave it satin matte.
Use a clear polymer (Zaino Z-CS - Clear Seal) the key is to add surface protection and depth without adding gloss.
Swisswax Opaque products for matte finish paint and vinyl wraps have been specifically developed (oil free) to ensure that they don’t change the appearance in matt paint or vinyl wraps.
1. Wash surface with Swisswax (SV) Opaque Car Bath
2. Prior to wax application the wrap needs to be totally free from oils and dirt. Clean all wrapped surfaces with SV Opaque Pre-cleaner.
3. Spray a 100% cotton micro fibre towel and apply to one panel at a time.
4. Wipe off with a clean 100% cotton towel
5. Apply SV Opaque Wax to one panel at a time, this wax will provide depth without adding a shine
6. Allow to dry for 10 minutes before buffing off and moving to the next section.
7. After the wax has out gassed and set-up, allow 2-3 hours and then buff the surface with a soft 100% cotton micro fibre towel
8. Use Quick Finish Opaque as a quick detailer to remove finger marks and smudges
also look at:
The Chemical Guy products seem to be another option
http://www.chemicalguys.com/Meticulo...wac_991_16.htm
