3WD|KW Lowering Kit for W463-A
SPONSOR
KW Suspension DDC for W463A
Fitment: W463A G63/G550/G500
Variant: DDC – Plug & Play
Hardness adjustment: Rebound and compression Lowering VA / HA: 0-30mm / 5-30mm
VA / HA adjustment: Thread / thread
Material: stainless steel
Admission: Parts certificate (§19.3) Axle load VA / HA: -1550kg / -1900kg
KW coilover kit DDC Plug & PlayThe “Plug & Play” solution for vehicles that have a standard electronic damper adjustment.
KW also offers you the option of combining the active series damper control of your sporty vehicle with the stainless steel KW DDC Plug & Play coilover kit. In connection with a stepless lowering, you can continue to use the existing active damper control in your automobile such as VW Scirocco, VW Golf VI, VW Passat, BMW Dreier and other models.
The best thing about it: Except for the exchange of the adaptive series suspension for the KW DDC Plug & Play coilover suspension, no further conversion steps or even modifications to the on-board electronics are necessary. The KW DDC plug-in connection simply connects the adaptive KW dampers to the original plugs from your car manufacturer. The series control unit then takes over the regulation and control of the KW DDC Plug & Play coilover kit.
Perfect symbiosis of an OEM control with the advantages of an adaptive KW coilover
Our chassis technology is compatible with the electronics of various automobile manufacturers. As a result, the adaptive KW DDC Plug & Play coilover kit is immediately recognized by the on-board electronics. In this way, all the displays and controls of your production vehicle remain fully functional and combine the advantages of an adaptive damping system with a stylish and sporty lowering of a high-quality KW coilover kit. Due to the exclusive use of stainless steel and durable components, the functionality of the stainless KW coilovers is retained under all weather conditions. With the dirt-resistant trapezoidal thread and the polyamide threaded ring, adjustment is also possible, for example, after a snowy winter. During a salt spray test, no oxidation occurred on the KW coilover struts. So the setting of the stepless lowering is not impaired even after years.
– the plug & play solution for sportiness or more driving comfort at the push of a button with outstanding optics thanks to a stepless lowering
– compatible with the
standard suspension control – vehicle-specific damper setups such as Comfort / Normal / Sport
– operation via serial buttons in the interior
Notes:
**VA + HA height adjustable (VA coil springs, HA springs with height adjustment + damper)
**Only for vehicles with electronic damper control
- https://www.3wdistributing.com/produ...ddc-for-w463a/
