G55 AMG (W463) Discuss the G55 AMG.
How to remove EIS module?
Old Dec 18, 2021 | 10:05 PM
Gznutz's Avatar
2010 Benefactor Dubsta
Hello all,
I have an intermittent starting issue where I turn the key into the spring loaded position and the starter does not crank. I suspect the EIS board needs to be resoldered. What is the easiest way to access this part?
Old Jul 24, 2022 | 12:04 AM
GTRaptorBoss's Avatar
2013 g63
I'm also dealing with the same issue trying to remove the EIS. I'm thinking i need to remove the steering wheel and get it out from steering column area since I can't reach from underneath
