cranks but doesn’t start
2011. g55amg
Hi Everyone, I have a problem with my g55 amg, 54000miles. The car has no problem with cranking but it will not start. Before the car has no problem starting but when the problem arises, I just let it sit for a few minutes and then start the car and it would go. But now, it only cranks. No warning on check engine light. New parts have been replaced: crankshaft position sensor, fuel filter and fuel pump. Just want to see if this is one the common problems w/g wagon. Any inputs, greatly appreciated.
Not really a common issue.
The 3 parts you have replaced would be my first guesses.
Next steps would be to check for any CELs, and then check that you're getting spark. Maybe check that the ignition coils are getting power?
Cosmas (06-22-2023)
Regards
Hi bro usually crank and CAM shaft sensors needs to be replaced. Also side note, try making sure you fully charge the battery and see if that works also. You can take that battery and have it charged at autozone/oreily free. Just some soft suggestions if your still having problems. After replacing cam shaft sensor and still not starting, you definitely might have a fuel line problem. You hear a fuel line noise usually when putting the key on 2 position, try doing that a few times to let it soak up? Best of luck bro.
