G55 AMG (W463) Discuss the G55 AMG.
Center Differential Issue
Old Nov 12, 2025 | 04:54 PM
aleksandar1099's Avatar
Top Answer: 1
Mercedes
I have a 2007 G55. I decided one day to try and use the diff lock buttons on the dash for the first time, they probably have not been used in a long time before that. Everything seemed to engage just fine, and drive fine in gravel with them engaged. I was able to disengage all three but drove a few blocks and then a loud noise came from under the car and it seemed like the car was in neutral. Even when in park, the car would still roll. If I engage the center lock diff then I could drive the car normally. If I tried to disengage the center lock diff, it would do the same thing where the car would appear to be a neutral and still roll even when in Park, and how to use the handbrake, otherwise the car would roll away. So far I tried to change the transfer case Fluid and tried to replace the center lock solenoid in the engine bay and I’m out of ideas. Has anyone had something similar happened to them or have some recommendations? I appreciate it!!
