Thermostat Replacement- ‘26 G63- 2,500 miles
Just curious -- did the Check Engine light come on right when you were starting it up, after you had been driving for a while, or when you were parking and shutting off the engine? Was wondering if there were any common patterns between the times when the light came on in your G.
Hopefully the parts are in by now, or will be before much longer, and you will be behind the wheel again in short order.
