General Discussion of Mercedes-Benz Classics Misc Discussion of the Classics, car spottings, museums etc.
Glow plugs control unit/relay pins - 2.9 OM602 engine
Old Feb 11, 2019 | 02:10 PM
CatalinG's Avatar
Mercedes Benz 207D
Hello! I need to change my glow plug control unit relay for my 5cyl, 2.9 OM602 engine. I already have one, but I'm not sure if I should try to connect it because of the different configuration of my smaller jack that goes on it - it has only 4 cables and the relay has 5 pins (50, 31, 15, LA, and a "T") - check attached image - I'm not sure what is the purpose of that connection in general, if somebody could explain, I would appreciate it
I saw on many online stores, that there are two types - one with 4 pins and one with 5 pins. But the distribution of the "main" 4 ones is the same (50, 31, 15, LA) - the other one has another pin with a "T" letter. I'm thinking that maybe I can connect the one I already have and leave out the 5th pin ("T") - anybody has any idea what is the T pin for? I was thinking that maybe someone around here knows if it would work to leave the 5th one out.
Thank you!
Old Mar 2, 2019 | 09:15 PM
chassis's Avatar
2017 GLE350 4MATIC
http://w124-zone.com/downloads/MB%20...2w124intro.pdf
http://w124-zone.com/downloads/MB%20...03/15-0705.pdf
http://w124-zone.com/downloads/MB%20...03/15-4000.pdf
http://w124-zone.com/downloads/MB%20...03/15-4111.pdf
http://w124-zone.com/downloads/MB%20...am/ETM/ETM.pdf
http://www.superturbodiesel.com/std/...d.php?tid=1716
The last two seem the most helpful. T means temperature, seems to be coolant temperature.
Old Mar 3, 2019 | 01:41 PM
CatalinG's Avatar
Mercedes Benz 207D
Thank you so much! Yes, it seems the T is for the sensor for the coolant temperature. Mystery solved!
In the meantime, I did the proper thing and bought a new relay But I really like to understand what I'm doing on my lovely Bob (207D) For about three months all I'm doing is learning mechanics like in school and applying what I learned on the car.
Thanks again! I really appreciate it!
