1969 280se w108 problem when shifting
Sounds like either a hydraulic or a vacuum related issue. Did you replace the hydraulic pump when the transmission was rebuilt? All (every one) seals and gaskets? Did you replace all vacuum components and hoses?
Also start with the easy stuff - is the transmission properly filled with the correct fluid? Are all connections secure: mechanical, electrical (if any) and vacuum?
