General Discussion of Mercedes-Benz Classics Misc Discussion of the Classics, car spottings, museums etc.
1992 W140 300SE pointers.
Old Sep 1, 2024 | 10:18 AM
Candyflip's Avatar
1992 W140 300SE
this is the project car that I got for free. I got a lot of systems back up and running I'm in the process of getting the soft clothes air pump off of somebody off of facebook. The transmission shifts pretty erratically the kickdown cable is adjusted correctly and I read online that it could be the conductor plate causing the issue anybody have any input on that? Fluids look good smell good and are the correct levels. The AC system also leaked down to basically nothing the AC compressor kicks on whenever you jump the low pressure switch and it sounds good no grinding or loud humming. What's a common place on the w140s that the AC leaks out? I'm aware behind the dash but I haven't put any dye in the system yet to verify that.
