General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
New rims now I got a bad case of the shakes! Help!
Old Mar 13, 2006 | 10:12 PM
stuffdogg's Avatar
1985 300d
Hi all, I'm a benz noob and I could use some help,
I got me an 1985 300d. It Ran somewhat smooth with only a minor shimmy past 60mph with stock 14" rims and well used tires. I hated the stock look and needed new rubber so I got some 7x17" aftermarkets. Now I have this earthquake of a shimmy when I get to about 50mph and sometimes 60mph. It is so bad that the car feels like it is going to fall apart! It is strange because somtimes it wont do it and run kind of smooth all the way to 70mph and other times when it starts to shake I can tap the brakes or let off the gas and it will stop the major shaking and let me continue to accelerate.
I thought it was the balancing so I put the stocks back on the front and keept the 17s in the back. The earthquake went away but then I put the 17s that were on the rear onto the front and the 17s that were on the front onto the rear and the earthquake came back. I can stick my head out the window and acctually see the wheel shake from side to side! Because I had no shaking with the 17s on the rear olny, I don't think the problem is with the balance of the wheels.
Now my question: Does it have to do with the size and width of the wheels or is my problem going to be the suspension system or something else?
I don't want to be stuck with those ugly stock rims. Anyone have any ideas?
Old Mar 14, 2006 | 12:37 AM
Ducman's Avatar
Black/Black E : Pewter/Black G Wagen
You need the new wheels to be Balanced by a Tire shop, I'm just curious why you assumed that the balance of the wheels is not the issue?
Old Mar 14, 2006 | 01:00 AM
stuffdogg's Avatar
1985 300d
They were balanced by a tire shop, but that reminds me, the shop's balancer was messed up and they used that stupid bubble level machine thing (do those work?). I'll go and get it done on a regular machine and see if it helps. Then again why no wobble when they were on the rear axel???
Old Mar 14, 2006 | 01:31 AM
Ducman's Avatar
you might not see the rear wabble with the naked eye but definitly feel the front because of your steering wheel, you might want the tire shop rebalance them.hope this helps.
Old Mar 14, 2006 | 08:31 PM
[180]'s Avatar
2004 E55 AMG
Did you use hub adapters?
Also, do you have hubcentric rings fitted? <-- This is important for centering the wheel onto the hub 'spline'.
Old Mar 16, 2006 | 08:22 AM
stuffdogg's Avatar
1985 300d
Ok, steering damper (shock) was 80% of my problem. It was totaly worn out. I spent $60.00 on the part and installed it myself In about 15 min! Wheels are balanced well. I use a local guy who has good equipment and I trust 100% and has perfectly balanced my wheels for years. I still have a slight shake that a can feel in the steering wheel at 60mph but nothing like It was before. I think I may have another steering or suspension component worn. Thanks for the help guys and please feel free to continue this discussion with any more suggestions.
