Best Headlight Bulb?
Edit: I found a cheaper source for the D2R 85126CX and D2S 85122CX.
The brightest (most lumens) would probably be the Philips 85126+/85122+, which are rated at 3400 lm but are the same color temp as stock (4200K, slightly yellowish white).
If you want a slight but noticeable blue tint for a lot less than the 85126 CX, go with 6000K bulbs from eBay. I wouldn't recommend going above 6000K, as light output decreases significantly at higher color temps.
Here's a comparison of different color temps. Note that the descriptions on the right don't exactly line up. The yellow on the bottom is 3000K.
Lastly, you could retrofit the 03+ headlights. I don't know what's involved, but I'm sure someone on here has done it. You would need D2S bulbs (Philips 85122) for the 03+ lights instead of D2R (Philips 85126).
Last edited by StarPower; Nov 10, 2009 at 06:42 PM. Reason: Found a cheaper source for 85122/6CX
Would all of these bulbs fit my 02 headlights since I don't have the xenons? I really like the look of the Philips bulb.
Unfortunately, you're not going to match the color of a HID bulb with a halogen bulb. Blue tinted "Hyperwhite" halogen bulbs don't look anything like real HID's, and are dimmer (less lumens) than a standard halogen bulb. The blue filter removes colors of light from the spectrum, making the light look bluer/whiter, but reducing output. This also reduces contrast and increases glare. You can read a lot more about this, and other lighting facts here.
So, what do I recommend? There are premium halogen bulbs that will give you a noticeable improvement in output (lumens) and a slightly whiter color (though nothing like HID's). The Osram Nightbreakers and Philips X-treme Power are the best halogen bulbs I've seen. Both of these bulbs use a combination of more precise filament placement/construction and different gas mixtures to achieve more output from the same wattage. Both bulbs also have a slight blue band (Nightbreakers have two larger bands) to give a bluer/whiter color, while maintaining clear glass for most of the bulb to maintain maximum output. The Nightbreakers looked whiter than the Philips X-tremes when I had them, but that was in a different car and not a direct comparison.
Double check what bulbs your car uses. I thought all W215's had HID's, with 2000-2002 being D2R and 2003-2006 being D2S.
