General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
No start
Old Apr 25, 2013 | 09:43 PM
mikemiranda70's Avatar
C220
No start
So we had a new starter lock out switch installed, because my wifes car didn't start. It seemed to solve the problem, but every once and a while it still won't start, unless you jiggle the shifter back and forth. Sometimes it takes a few minutes and then it will start.... Any ideas what could be the problem??
The car is a 1996 C220.
Old Apr 26, 2013 | 08:22 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
When you say "won't start", do you mean the engine will turn over but the engine won't start or the engine won't turn over? If the engine won't turn over, i.e. it's like everything is dead, your neutral switch may be the culprit. Either an adjustment or replacement may be in order. Good luck with the repair.
Old Apr 26, 2013 | 10:22 AM
MOTOJAE's Avatar
2002 CLK55
Try to start the car in neutral see if that helps.... if it starts ok it is the neutral safety switch.
