1976 W115 200 GAS - white smoke in tailpipe exhaust
ARwin
You don't mention mileage so it's difficult to give you any other suggestions.
Good luck with your new car
A benz mechanic told me that the W115 engine is tough that even if there is a blow by it is still ok as long as i would perform regular oil change and adjust the valves every tune up. He also recommended not to use synthetic oil.
Should I take his work for it? Having sleepless nights for fear of an overhaul
When you check the emission by putting your hand near the tailpipe, if you do get a clear condensate on your hand before wiping your hand clean touch the condensate to your tongue. If the condensate tastes sweet you probably have an antifreeze contamination.
Did the smoke test. It appears that the residue is water and not oil. However, I also checked the raidiator and there is no decrease in the water level nor oil in it. The water is pink and i guess the PO uses coolant in it. The temp is also normal. Its below 80. The oil in the engine is clean. No signs of water leak. If it is water vapor shouldnt it dissappear after a few minutes?
If this is the case can I now sleep soundly at night?
