General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Licence plate light fault
Old Dec 20, 2013 | 12:21 PM
Johnxwilson's Avatar
E320 2008 estate
Hi,
how do you clear a licence plate lamp out message on a 2008 e class e320 estate, I have replaced the lamp and it is working but the message still appears and I can't manage to reset it.... Very annoying...... All help appreciated
Old Dec 28, 2013 | 02:24 PM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
The problem may not be the bulb but rather corrosion resulting in higher ohm reading thereby throwing off a fault. I just had to replace mine because of corrosion. It's an easy job and the lights are not expensive directly from Mercedes.
Old Dec 28, 2013 | 03:17 PM
E320 2008 estate
Lamp out
MrB
Thanks for your reply had a look at that but all seemed fine put it back together again and 2 days later the fault message just stopped. Don't really know why but it's gone now
Thanks for your suggestion
Regards john
Old Jan 11, 2014 | 04:25 PM
barn9's Avatar
1998 Mercedes e320
Just purchased a '98 e320 that is doing the same thing. My problem is that two of the three screws holding the cover are frozen solid. Have tried PB Blaster to no avail, but will keep trying before the last choice of drilling and extracting. MB dealer is 50 miles away, anyone happen to know what bulbs I need? (The one that is working looks a little foggy, so thought I might just replace both of them). Appreciate any help, thanks!
