General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
S400 w220 Please help
Old Aug 12, 2015 | 12:41 PM
Milos-13's Avatar
Mercedes s400 w220
For the last period of time my car feels like going to die , the problem occurs when i push accelerator pedal from 0 km and immediately I release it the car feels like if it would die kind of jumping , another problem at higher speed when i push gas pedal the car has same problem but when it changes gear its fine. I will upload a small video to see, but it is hard to catch on video.
Old Aug 13, 2015 | 07:09 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Sounds like it could be dirty or defective MAF.
Old Aug 15, 2015 | 06:28 PM
MikeKerr7's Avatar
S-series 2003 S500 4matic
Change the fuel filter, on the W220 a failing fuel filter can emulate a MAF,MAP, and gas pedal failure. Eliminate the fuel filter as a possibility, and if you still have a problem go from there.
Old Apr 17, 2016 | 06:05 PM
Milos-13's Avatar
Mercedes s400 w220
Guys I don't think It is MAF filter, I have this problem already for long time I got S400CDI and when i Push the Gas Pedal like to 5% and immediately stop accelerating and I let the Gas pedal on 0% acceleration the Car Starts Pushing and jumping in the first gear until it shifts or if you brake and it Dies. (EXAMPLE: you are in a traffic jam the car a front of you accelerates and then immediately stops and you do thee same the car kind of pushes you forward and if you HIT the BRAKE on 100% then the car eventually DIES and writes ESP visit the WorkShop and I have to start the car again) sorry for the late reply but i could not have found my password for this forum and could not have fount this post without it. Thanks
Old Oct 19, 2019 | 05:55 AM
PRETTY.BOY1990's Avatar
E280
you think i should have it cleaned ? what about injectors ? cuz last week i changed the fuel filter much better after smoother , it hadn't been changed since 150k km , it was very very dirty , maybe it caused the injecteros to blocked ? i bought an aftermarket fuel filter cuz OEM is veryyyy expensive
Old Oct 19, 2019 | 05:23 PM
E280
what does MAP refer to ??
Old Oct 19, 2019 | 06:12 PM
chassis's Avatar
2017 GLE350 4MATIC
MAF = mass air flow (sensor)
MAP = manifold absolute pressure (sensor)
