General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Do I have keyless Go?
Old Sep 25, 2015 | 03:46 AM
vpstylee's Avatar
2013 Mercedes E 350 Coupe with P1 & P2
By accident I touched my car door handles and the car locked. If I grab the handle, the car will unlock. However I do not have the push button start. How can I figure it out? I have a 2013 e350 coupe with p2. Could it be that someone took off the ignition button?
Old Oct 9, 2015 | 02:22 PM
mcorssen's Avatar
2004 w211 E320 4matic
Yes it very well could be, the best way to tell if you have keyless go is to look at the outer side of your door handle. If it has a small square-like patch that you can tap to lock, your in luck, put your hand on only the inside and your car should unlock, as long as the key is within about 2-3 ft from that particular door. The keyless go button can be easily popped out of the ignition and finding a new one on eBay/ Amazon should be relatively easy/ inexpensive. And it will just pop in place of your key, foot on the brake, one tap and your car should start right up, hope this helps
