General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
FOG LIGHT L, wont go away
Old Oct 5, 2015 | 06:58 PM
tyson13's Avatar
c class sportcoupe 2001
Hello,
Sorry if i post this message at the wrong forum.
Anyway, I am really tired of this message saying check FOG LIGHT, L.
They do work!
Is it a sensor problem? If it is, where is it located?
Oh ive got a old c class sportcoupe from 2001.
Old Oct 5, 2015 | 07:53 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Try swapping left and right bulb and see if the issue follows the bulb to the right side. Although they appear to work, you want to make sure there's nothing wrong with the current draw, which would trigger codes. If it stays on the socket, check the ground wire to make sure there's no burn marks (MBs are notorious for cheap ground wires).
Old Oct 5, 2015 | 09:00 PM
tyson13's Avatar
Thanks for yr awnser mate. now i know what to do or what to look for. ill leave a message if it worked for me.
thnx for the info!
