General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
E63 brakes and rotors help
Old Nov 19, 2015 | 03:42 PM
sejals's Avatar
2012 GL 450
I have a 2011 E63 with 50k miles in need of new pads on the front and rear. the mechanic recommends changing rotors and pads to avoid future brake noise and squeal. Any experience with changing pads only? The front rotors are about $1,000 each alone. Thanks
Old Nov 19, 2015 | 07:01 PM
07E63DABEAST's Avatar
07 E63
rotors
Have the rotors been changed before? 50k miles is excellent mileage for original rotors. You need to change them.
Old Nov 20, 2015 | 07:18 AM
mrbobby's Avatar
2003 S500 4Matic (SOLD) + 2004 S55 (SOLD) 2005 CLK 500 Cabriolet 2008 S 450
Welcome to the pricing world of AMG
Old Nov 21, 2015 | 12:17 PM
KENNY94945's Avatar
The front rotors have a minimum thickness.
So check that first.
Your mechanic is offering good advice.
If you do not have minimum thickness you could turn the rotors, yet you now have the risk of rotor wrap quicker than expected.
Just pads? Risk of brake squeal is high. Stopping distance may increase.
If you are keeping the car, do rotors and pads IMO.
Yes AMG front rotors are typically "over the top" expensive.
Good luck with your decision.
Old Nov 22, 2015 | 08:43 PM
sejals's Avatar
2012 GL 450
First set of Rotors . Don't think they could be turned because they are slotted and drilled from what I understand. Has anyone used anything aftermarket? The mechanic tried to get Brembo rotors but the supply houses listed them as out of stock and no information on re-stocking.
Old Feb 4, 2016 | 03:07 PM
FromM3toAMG's Avatar
07 E63
I'm in a similar situation, when i bought the car i was told that the rotors are good for two sets of pads, any truth to this?
I replaced the rotors and pads about 30K miles ago... am i good for now or do i need to do the rotors too?
