General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Turned key too fast
Old Mar 2, 2016 | 12:55 AM
Clerkj's Avatar
SLK55 AMG
Turned key too fast
I turned the key fob too fast in an 2007 slk55 AMG, I guess I didn't turn it all the way or something but, it clicked as if it was going to start but it didn't so I turned it again and it said to remove key. When I inserted it again and turned normally it started but it was kind of a rough start/idle but everything was fine while driving... So is it fine?
Old Mar 2, 2016 | 08:13 AM
nycphotography's Avatar
'15 T&C & '14 SL63
When you turned the key too hard you probably dented the frame. Probably be totaled.
You Hit the Frame the Car Does Not Run Right
Nah, just kidding. If the ignition is working, then it's probably fine.
