rotor removal question - would like advice please
I am in the process of replacing a front bearing in my 2012 GL350, and am not sure about removing the rotor from the wheel hub. I am not sure if the rotor is frozen on, or if I need to remove the large enter nut first.
I cannot find this answer with the search function, and can't find a guide anywhere for this job.
I thought I had found a youtube video that explained the process well, but my vehicle looks different after I removed the wheel. I believe that the bearing went bad because I do not have a dust cap in place. I will need to order one.
My question is once the tore bolt is removed, do I remove the center nut first, or should the rotor come off with the center nut still in place?
Thank you for any help with this.
Andrew
Thank you for the reply!
Last night I had the caliper bracket off and hanging up out of the way, and took the small tore screw off at the 12 o'clock position. At that point I thought the caliper would pull off, put it is not budging even a little. That is why I was thinking that the large nut in the middle was possibly holding it on. I wasn't sure what to do so then I put everything back on except the tire and took that picture.
In all of the videos I have seen, there is an allen key tightened into a nut that holds the wheel hub onto the spindle. I could not see this on my car. I wasn't sure if my vehicle was somehow totally different than all of the others I have seen on youtube.
I will repeat the process from last night and try to use some more force pulling the rotor off.
Thank you for the help.
Its AWD.
I was just planning on removing the wheel hub and bringing it to a machine shop along with the new bearing. I didn't realize that there would be that much of a difference. I was thinking that this would be a DIY job, but maybe I am totally wrong. I have replaced hub and bearings before in my truck, and did not think this would be too much different.
Is this different than I am thinking?
Thanks for the help
