The Darn E55 Supercharger
First I have a cylinder misfire code from my scan tool but i have swapped coil packs and plug wires to no avail., Also my supercharger, Last year summer i noticed that driving i was losing power I would stop the car for an hour or so start it back up drive all is good, this goes on for 8 - 9 months so i park it for 5-6 months just starting it up every now and then (to keep the battery charged).
Then on a nice day I decide to take it out for a quick spin, waddya know no power at all... ??? WHAT THE HELL!! So I pull out my scanner and realized I have a misfire on cylinder 8 THATS it. I checked the single relay in the trunk on the right side, What else is there to check?
I currently have an 180 ASP, Bigger injectors, Johnson pump, heat exchanger and tune, larger throttle body (80MM).
could someone shoot me a link of the wiring diagram/location of the most other common areas i need to check of this issue...
Thanks in advance
