Nano Paint Question
More importantly to me, can my w126 be resprayed with nano-paint when the time comes, or does MB treat the body differently to bond with nano-paint molecules? I am hoping that if I have a bare metal respray I can have it nano'd...
Thanks for answering my Q's.
I saw that someone asked the same question on amg-owners-club. I see that it's a matter of using one of the approved clearcoats, removing all trim from the affected panel, and baking the clearcoat on.
Scratch Resistant Clear Coat:
Mercedes-Benz has developed an innovative new clear lacquer paint technology; this nano-particle clear coat incorporates microscopic ceramic particles in a clear urethane lacquer. The clear coat is factory applied and then ‘baked’ in a high-temperature drying oven forming a hard scratch and fade resistant finish. This paintwork system significantly improves surface gloss over conventional clear coats.
It is also provides better protection from the necessary automatic car-washing, and concentrated detergents used, as it's illegal to wash your vehicle and allow water to flow to a storm-drain in Germany due to environmental regulations.
Paint film surface maintenance is the same as for other systems, removing surface defects entails limited and controlled clear coat removal.
On soft paint finishes like water-based paint with a clear coat or a single stage paint it’s simplified because they are easier to abrade. You need to remove the paint surrounding the scratch to blend it in with the immediate areas, which means you must remove hard paint without causing further damage or introducing more surface scratches.
