wheel compatibility among different MB classes?
newb post
trying to figure this out asap
fiancee just damaged 2 wheels on her 2016 E350 sedan so i am trying to find replacement wheels
can wheels be swapped between different classes? like a C class and E class?
it would help widen the search parameter for used wheels
thank you
thank you
Check the inside of her wheels. Most rims have the offset stamped on the inside. I believe the 5 bolt lug pattern has been standard for many years. If you find a close enough offset she will be fine.
XKxRome0ox (07-27-2017)
No - offset is also directly related to the width of the metal wheel. And some Mercedes wheels use different wheel bolts due to hole depths. You also want to get the same wheel diameter so you can use the same tyres.
Its cheaper to send them to a wheel repair shop, which is what i did on my GLK350 wheels.
