General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Ntg4 comand shuts off when open front doors
Old Aug 1, 2017 | 05:37 AM
Cablecatty's Avatar
Mercedes w204 c220 2009
HIYA ALL.W204 C220 2009.HAVING PROBLEMS WITH NTG4 COMAND SYSTEM.WHEN I OPEN ANY FRONT DOORS IT GOES OFF AND BACK ON AGAIN.HAVE RESET COMAND SYSTEM STILL PROBLEM.HAVE VIDEO IN MOTION FITTED.THOUGHT IT WAS THAT BUT DISCONECTED,BUT STILL SAME ISSUE.ITS OK IF I OPEN AND CLOSE REAR DOORS.JUST FRONT DOORS.I HAVE FOUND THE FAULT NOW IN CASE SOMEONE ELSE HAS SAME ISSUE.GO INTO ENGEERING MODE,GO DOWN TO HU SETTINGS.NO7.THEN GO TO 7.5 PERIMITER SETTINGS.GO TO MOST.THIS SHOULD BE OFF NOT ON.ONLY ON IF EXTERNAL AMP BEING USED.THEN COME OUT OF ENGEERING MODE.SWITCH OFF IGNITION.THEN BACK ON,COMAND WILL RESET.THATS IT
Last edited by Cablecatty; Aug 4, 2017 at 07:34 AM. Reason: Ntg4 shuts off with doors open/close
Old May 4, 2024 | 11:19 PM
Toofones's Avatar
W204 C63
Confirmed fix!
This problem has been annoying me for months! Thanks for taking the time to post the fix. Such a simple solution!
