General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
ISPY UNKNOWN DRY OIL SMELL ISSUE???
Old Nov 23, 2018 | 03:18 PM
IAmBrokeBoy's Avatar
2000 C230 Kompressor W202 2004 C320 Sport w203 2005 S55 AMG
I smell every now and then a dry oil, hot antifreeze kind of smell, but it also smell kinda of like a burning paste, sealant, rubber.
There is also weird glue paste sealant stuff on one of my under body pipes that actually does get hot when driving, cause that's what pipes do...
2000 C230KOMPRESSOR
( Can provide clean pictures of any part.)
No milky resevoir, no random smoke, all pulleys turning except my AC sadly.
Drives normal except for the loss of power which I'm sure my MAF is the cause of, as it only happens after long excesive driving.
Radiator hoses are soft and not hard. Engine doesn't shake and seems normal. Under hood looks normal. No difference in exhaust smoke.
Random low coolant light every now and then, when I drive its gone.
Let's play ISPY THE PROBLEM.
Old Nov 23, 2018 | 03:24 PM
I've came to a subconclusion it can't be a cracked block, it can't be a blown head, and it can't be a bad water pump, I'm honestly thinking it might be the glue paste stuff on my pipe burning, but then again the smell is a little chemically.
Old Nov 24, 2018 | 10:28 PM
Update: I'm guessing that **** on my pipe is a melted plastic bag. ..
Old Nov 18, 2019 | 05:30 PM
Literally came back to this one to laugh.
Old Nov 20, 2019 | 04:04 PM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
Alot of guessing. Any CEL, scanned for any saved codes?
Any oil film in the MAF, the lines or the air filter box?
Have you checked to see if your oil separator is still working correctly?
