General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Tachometer & Speedometer Connection for M110 Engine Inline 6
Old Oct 8, 2019 | 11:37 PM
ilovehon's Avatar
W112
Hi Everyone,
I am working on a Mercedes 300SL Gullwing project using a M110 engine. I have a mechanical tachometer and speedometer off from 280SE and both are using cable drive. How can I connect the mechanical tachometer to the engine to get the tachometer working. Is there a terminal available on the engine I can connect the tach cable. I know I can get the pulse signal from the ignition coil through the "-" side but my tachometer is mechanical version. How can I get it working.
Is the speedometer cable connects to the end of the transmission. Please advise if anyone can help and thank you
Tony
