I need a replacement key for a Euro version S600. I have one original key. The spring on the flip key is gone. And the hpousing is worn out. The mercedes dealership says that they only have a standard key available for a 1991. The full flip out blade key and remote is no longer available. How can I get a complete and new key, housing and remote? PLEASE HELP.
I have a working original key (with functional IR) and plastic case. It is very worn. I need a second key as a backup and a new case. The MB dealership said they only have a standard key. No case or remote.
That is correct. MB no longer makes or sells remote keys for that model and many others. That means that you cannot buy another remote key, anywhere.
Only the valet keys are available from the stealership.
Optionally, you can obtain from fleabay, aliexpress etc.. a replacement non-oem FOB shell casing, uncut blade (key) to replace you oem housing and spring. Make sure you remove the chip, if yours has it, located inside the FOB casing.
