Overheating a250 2014 help appreciated
I was driving home when my serpentine belt snapped, I only noticed when the temp was getting to 120 so I pulled over and noticed it was snapped, after the car was recovered home I fitted a new belt and went for a drive, after 5 minutes the temp gauge inside was shaking around going from 90 to 120 in under 2 seconds then back down to 100 and all over the place. I have no codes logged and have flushed the coolant to see if it was a blocked coolant hose or airlock but now it’s only taking 3 1/2 litres of coolant in so I’m thinking it’s the pump seizing which has caused the belt to snap? But I did check the pulley before replacing the belt and it was fine.
Any ideas what could be the cause? I think I’m going to replace the pump myself which is a big job but want to see if anyone els has any ideas to save me some time and money. I have a new thermostat and coolant sensor I can fit but don’t want to change them if I don’t have too.
Thanks for reading any help much appreciated!
