General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
How to Replace Cabin Air Filter for 2015 Mercedes-Benz GLK350
Old Mar 13, 2022 | 12:34 PM
charlesbeb's Avatar
Mercedes-Benz SUVs M-Class (W166)
Hello all
This instruction will show you guide on how to replace cabin air filter for 2015 Mercedes-Benz GLK350. The cabin filter is located on the passenger side of the vehicle, under the glove box.
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-7
Time: 30-60 minutes
Tab: $23 to $50
Talent: 1
Tools: T20 Torx driver, rag
Parts Required: New air filter
Hot Tip: Place a cloth under the filter when removing
Performance Gain: Breathing cleaner air
Complementary Modification: Change engine air filter
Steps:
Use a T20 Torx bit remove the three Torx screws that secure the foot panel to the glove box assembly.
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-1
Pull the flooring backwards so you can remove the sealing panel easier
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-2
Remove the footwell ceiling panel
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-3
The filter is secured by a plastic lock and sometimes metal clips on either end. Pry those off it.
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-4
Slide the plastic lock to the left to drop the filter.
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-5
Remove the old filter from the housing and clean out any debris inside.
Install you new AQ 1161 C filter into the housing with its air flow indicating arrow pointing towards the back of the car.
Slide securing plastic over the housing tabs to lock it.
How-to-Replace-Cabin-Air-Filter-for-2015-Mercedes-Benz-GLK350-6
Reinstall other parts, replacement is finished.
Recommended replacement every 15,000 miles or one year, refer to your vehicle owners manual for specifications.
