General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
HELP Fault Code B2806-13 The sqib for refrigerant accident safeguard 1 has a malfunti
Old May 26, 2022 | 06:03 AM
rangy's Avatar
250d Blue Tech sport C Class 205
Anyone any help with this, c class c43 coupe 2018 it had a wee bump at front, driver side bags deployed and now repaired/replaed tho I still have this code showing up
Code B2806-13 The sqib for refrigerant accident safeguard 1 has a malfuntion there is an open circuit
Its a fire extinguiser in an accident to release the aircon gases etc
I was thinking replace the refirgerant part number = Gas Generator - Mercedes-Benz 2138606001 and it would solve the problem?
Or is it a case of replaing a squib? or is the squib forming part of the part above?
when i look at the part in here part #10
Refrigerant Accident Protection for 2018 Mercedes-Benz C 43 AMG® | Mercedes-Benz Parts
I can see it has a related part called = Rs Elect Wire Harness - Mercedes-Benz (204-440-18-54) Description:Squib K88. Battery terminal pyrofuse F39. Gas generator squib R12/69. St_f1. P fuse box.
Is it just this 1st part I need? or the other? or both?
Could someone please help, I have called meredes 4x dealerships for info they cant/wont tell me anything they just want money for booking it in to tell me the answer
I am hoping someone in here could tell me where the loation of the part is and how i gain access to it (engine right but where?) and what part to replace, the sqib or the gas generator is it combined?
ignore the second fault that has cleared
TIA
TIA
Old Apr 30, 2024 | 06:04 PM
themechanic97's Avatar
C63 w205
Did you fix it ??
Did you fix this issue I have the same problem
Old May 29, 2024 | 05:51 PM
Ricardo92's Avatar
C200
Tengo el mismo error,
[QUOTE=rangy;8569923]Anyone any help with this, c class c43 coupe 2018 it had a wee bump at front, driver side bags deployed and now repaired/replaed tho I still have this code showing up
TIA
He visto que la botella con el gas extintor se encuentra en la aleta delantera derecha, tampoco se si con cambiar eso basta o el cable o ambas cosas.
gracias de antemano
Old Jun 15, 2024 | 06:52 AM
DamoC43's Avatar
c43 Estate 2019
Did you resolve this? I've same issue and code. Have ordered a replacement gas bottle located behind drivers front wing (UK RHD) and i'm hoping this sorts the code otherwise i'll have to replace the connector also?
Old Aug 23, 2024 | 05:31 AM
Ricardo92's Avatar
C200
Se solucionó?
He cambiado la botella de gas, y para mí desgracia el error sigue saliendo, a vosotros os ha desaparecido?
gracias
