Strange Starting Problem
One way to (possibly) know it is a crankshaft position sensor is to observe the tach when you attempt to start the engine and the engine starts. Then whenever you subsequently start the engine pay attention to the tach. Word is if the crankshaft position sensor is bad the tach will not register any RPMs. Instead the needle will be lifeless.
Many thanks for your help on this issue. I have been tied up but plan to check the crankshaft position sensor just as you suggested.
I guess the question I have is if the crankshaft position sensor is bad, why does it work after waiting for 2 hours or so. It's not even even erratic or random. I wait for 2 hours or so and it starts back up without any problem. At first, I thought it was the fuel pump but ruled it out just because it always starts after some wait.
Best,
Rick
