General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Selected gear D, actual gear N +PROBLEM +PAY FOR SOLUTION
Old Sep 5, 2022 | 11:34 PM
Alextrem87's Avatar
C220 cdi (Sport coupé 2002)
Exclamation Selected gear D, actual gear N +PROBLEM +PAY FOR SOLUTION
Hello, I'm new on this forum. So.. I am experiencing a REALLY STRANGE PROBLE and is making my brain explode..
So, when I switch into P, N, R everything works fine.. Even the car drives in reverse..
But when switching into D, nothing happens, it stays in neutral as you can see on the picture, no sound, no change, the car doesn't move, and when accelerating (in D), it is limited to 1100rpm..
I really want to save this car.. I would be really thankful to hear someone that maybe knows what can cause this random problem.. On the scanner don't appear any fault codes, it is a good scanner, but not Mercedes DAS Xentry..
Happy to hear from you and as I said, I would pay gladly 40€ for someone's help!
Here you can see, when I swith into D, the gear selector works fine but the trans doesn't receive the signal and still keeps on N
Old Sep 6, 2022 | 12:42 AM
Alextrem87's Avatar
No help?
Old Sep 9, 2022 | 02:16 PM
BenzNinja's Avatar
Former Vendor
Originally Posted by Alextrem87
No help?
never touch coding with scanners
don't expect scanners do coding
buy a scanner only if you just want to read "some" codes
there is no other solution to work properly on MB than Xentry
