Wireless Scanner: Engine, Trans, ABS, SRS, TPMS, Battery Initialization, & more!
- Read and erase check engine, transmission, ABS (Traction, Skid, ESC, Power Steering, suspension), SRS (Seatbelt, Airbag, Horn), TPMS, all Module/Individual Modules (HVAC, Lane Assist, doors, headlights, windows, convertible top, etc.)
- Read Permanent check engine codes, I/M Monitor Status & Freeze Frame Data
- Transmission Fluid Temp (Static), Brake Pad Check, Oil Life, Oil Level, Odometer, Battery Status, Tire Pressure
- Battery/Alternator Test (Gas, Diesel, Hybrid, Plug-in Hybrid, Electric)
- Oil Maintenance Reset OBD, Battery Reset Procedure, Battery Initialization, TPMS Relearn Procedures
- View and record Live Data to playback. Up to 8 graphs and can overlay up to 2 graphs. Offline mode that will still record live data if driving through any area with no service.
- RepairSolutions App: Run unlimited diagnostic reports that save in Report History in the app or save it to a smart device to email, text, or printout.
The RS2 app offers Fixes, Predicted Repairs, Scheduled Maintenance, Technical Service Bulletins & Recalls, Cost to Own, Warranty Status, Enhanced Vin Decode, Optional Health & History Reports, links to your replacement parts, scheduling repairs through RepairPal if needing to find an available mechanic.
Only English and Spanish
Disclaimer: This app is designed for exclusive use within the United States, Canada, and Mexico. Users outside these countries will not be able to use the app, even if downloaded through irregular means.
Innova 1000 wireless scan tool
Discount code: 15% off: FORUMS15
