General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
Ac problem
Old Jul 30, 2025 | 09:25 AM
Rj1012's Avatar
Ml350
Ac problem
Hey all , I have a 2013 ml350 w166 that the ac on the driver side seems to periodically blow warm air . I think it might be the blend door actuator, but I’m not 100% sure any help would be greatly appreciated. Thank you.
Old Sep 16, 2025 | 12:04 PM
Jeeped60's Avatar
2015 ML350 4Matic, 2012 Jeep Wrangler
AC hot on drivers side
I had a local shop use a bore scope, fiber optic camera, peek down the ac ducts. They said two blend doors were broken. MB in St. Charles, IL quoted me $3,300 entire hvac box assembly. They would only sell it to me with a service appointment to R&R the unit for 15 hours x $200/hr.
July 2024 I sourced a 2014 box (salvage yardl) for $400. 12 months later that one broke exactly as you described w/hot air on the drivers side. I have yet to find a lower cost solution.
Old Sep 16, 2025 | 12:06 PM
Jeeped60's Avatar
Forgot to mention mine is a 2015 ML350 w/77k miles.
Old Sep 16, 2025 | 08:14 PM
Alexie's Avatar
It's almost certainly the blend door actuator. A common failure on these. You'll need a capable scanner to confirm which one, then replace it. It's a tight job behind the dash but fixes the issue.
