General Mercedes Discussion Use this forum to discuss general Mercedes-Benz topics that are not specifically model related.
PSE replacement
Old Jan 30, 2026 | 10:31 AM
Reddog378's Avatar
2011 SL550
PSE replacement
PSE lacks sufficient pressure to make door locks work, can’t find any leaks. What is considered reasonable price for to replace this on 2011 SL550
Old Feb 2, 2026 | 12:49 AM
smgak's Avatar
C230K
Rebuild it, replace the PSE motor
Old Feb 3, 2026 | 06:43 PM
Alexie's Avatar
Parts alone for the pump are around $500-$800. With labor, a reasonable independent shop price is $1,200 to $1,800. The dealer will be much higher. It's in the trunk behind the lining. If you're handy, the part swap itself isn't the worst, but the system needs to be properly initialized with STAR afterward.
Old Feb 3, 2026 | 10:47 PM
Reddog378's Avatar
2011 SL550
Sounds about right the cheapest genuine Mercedes part I have found is 1200. The repair shop wants to mark it up 600 plus 2 hours labor. Puts it a little over 2000
Old Feb 7, 2026 | 09:26 AM
Reddog378's Avatar
2011 SL550
So if replace it myself I will still have to get the shop to program the new one, right?
Old Feb 11, 2026 | 02:39 PM
smgak's Avatar
C230K
Yes
Old Feb 13, 2026 | 09:42 AM
GTIBlack's Avatar
Mercedes SL R231
What programming is needed? I doubt it is a theft part that is coded to the VIN. If programming means “initialization” or “learning”, that can be done with some Mercedes-specific scan tools (under $250) or by XENTRY. If you don’t have a Mercedes scan tool, now is the time to get one.
