GL with Bucket Seats? Aftermarket?
My wife is "not sure" if we should get the GL 450 for a couple of reasons, but she said if it had bucket seats (like the R Class does) in the 2nd row, she would definitely give it her seal of approval.
Has anyone seen or heard of a place where you can have aftermarket bucket seats installed instead of the bench?
You might be better off with a different vehicle, changing the 2nd row to buckets is going to make it nearly impossible for the 3rd row to function.
Check with your local bodyshop, they can probably tell you if they know of a shop that can do it. At most, it'll require some rails/mounts to be welded/bolted onto the floor, with some sort of re-enforcement plate to prevent it from ripping out during an accident.
