Suspension Problems
Old Mar 12, 2007 | 02:06 PM
moneybagzs65amg's Avatar
2007 S65AMG, 2007 S550 w/ AMG Pack, 2007 GL450 Premier, 2006 S500, 2007 CLS63AMG
Question Suspension Problems
Today while driving my GL, I had the car raised. After a while, a message came on the screen saying "Compressor Cooling Down" while showing a picture of the car. Then later I noticed that a picture of the car was on the screen, but this time the car said "Visit Workshop", while I was on my way home. After I got home, I looked at the car, and the front end of the car was very very low. It was so low that it was a very small bump away from hitting. What do you guys think could be happening? Thanks.
Old Mar 12, 2007 | 03:53 PM
MERCFAN's Avatar
Mercedes GLE 63S / GL 420 CDI / C250 Diesel 4 MATIC
Angry
From what I can see you have an airmatic problem. Could be the airmatic system or only a default pump.
You have to visit your dealer. I do not recomend to drive the GL with that problem.
Old Mar 12, 2007 | 07:45 PM
mbslk350's Avatar
2021 GLS450, 2015 E250BT 4Matic, 2007 GL320CDI, 2005 SLK350, 2001 SLK320
There were several postings in the past about this issue. There were a bad batch of air pumps that had to be replaced. The symptoms in your post are exactly the same as those mentioned previously. You need the pump replaced.
https://mbworld.org/forums/showthrea...highlight=pump
Old Mar 12, 2007 | 09:54 PM
boxboss's Avatar
I assume you have a new GL...the airmatic issues all posted were some time ago and I thought those had been resolved.
Old Mar 12, 2007 | 10:21 PM
Nevada Jack's Avatar
2011 E350 Cabriolet..White and Almond Mocha
His profile says he has a GL450 Premier which could indicate why he is having the pump problem.
Old Mar 12, 2007 | 10:30 PM
boxboss's Avatar
Ah-ha...I didn't look closely enough. NJ, you are correct, again.
Old Mar 12, 2007 | 10:32 PM
neodoc's Avatar
2017 Rolls Royce Wraith, 1999 CLK Cabriolet, 2023 Genesis G90
I had the same problem a while back, when MEINTRK (my license plate, by the way) became my "lowrider." The compressor for the front suspension was replaced and I'm no longer driving a lowrider, homes. Sorry...couldn't help but reminisce about my days as a "vato." Once replaced, you should be all right.
Old Mar 12, 2007 | 10:40 PM
Lukester's Avatar
Had the same problem but mine said "Airmatic cooling down". Dealer had to replace the strut assembly.
Old Mar 12, 2007 | 11:12 PM
I took in the car today, hopefully they can fix the problem soon. Maybe I will hear from the dealer tomorrow about what is going on with the car. Also, is it because it is a Premier Edition, thats why its having problems? Thanks everyone for your help.
Old Mar 13, 2007 | 12:36 AM
oknish's Avatar
'07 GL 450, '02 S 80 T6
I am guessing that since PE edition was the first batch of GLs released to market, this problem has been showing up in PEs and earliest built cars. So don't think of it as a problem with PE. Rather it looks to be an issue with initial builds that has since been fixed.
Old Mar 13, 2007 | 10:23 AM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
On the subject of the air suspension...........I have read all the literature, etc. on the ability of the system to RAISE the height of the vehicle by an additional 3in. Is there also the ability to LOWER the vehicle while it is parked ( for loading purposes)? I know the touareg has that option.........
Old Mar 13, 2007 | 02:13 PM
oknish's Avatar
Not available in GL.
Old Mar 13, 2007 | 08:15 PM
BigJim's Avatar
I had similar problems with my 2006 ML, it looked like the car had been lowered too far and the ride was terrible. In the end it turned out to be a faulty air pump which kept blowing the 40amp fuse under the hood. That's where you should start, have a look in the fuse box and see if one of the 40amp fuses have gone.
