3-Zone automatic climate control
Old Jul 1, 2007 | 12:09 AM
293's Avatar
293
GL 450
I am reading the factory manual regarding the 3-zone automatic climate control and it appears you can control the rear temperature from the front control unit but you cannot select the rear air distribution or control rear air volume from the front control. Is this true?
If you can control the rear distribution and rear air volume from the front control unit can some one please explain how.
Thanks in advance.
Old Jul 3, 2007 | 02:47 AM
2thfixr's Avatar
Depends where I'm going.
Thanks in advance.
You are correct. You can only change the temp for the rear zone and the system automatically determines fan speed and air distribution. It stinks but at least it works.
Old Jul 3, 2007 | 05:38 PM
boxboss's Avatar
There is a cheat: set temp and fan speed for the driver's side then press "Mono" to have passenger and back settings mimick the driver's.
I know, I know, that's probably not going to accomplish what you are wanting to do...but it is possible, in the theoretical sense, to adjust temp and fan speed from the front. (No distribution, though.)
