Transmission question.....
Well.........I have the ORP and no rocker switch and no mention of this capability in the owners manual so I sort of figured MB had dreamed this up and then nixed it but failed to take it off the website ...... but when I saw it was still on the website for 08 I began to wonder if somehow I'm missing something because is talks about it as if it's standard regardless of ORP or not...............very confusing!
Thanks for trying to clairify.......
Thanks for trying to clairify.......It is not standard and I agree the site is confusing as were the reviewers who also assumed it was standard.
Uhmmmm.....ok, I do have that switch but thought it dealt with the suspension ONLY........I'm on my way out the door to investigate further....."the plot thickens!"
Just for fun......I put in call to MB customer service: got Miss "I know everything" who started to describe the system that is found on most MB vehicles.....after I interuppted her twice and clearly described what I was reading on the MB site and in the GL450 brochure and what I was NOT finding in my drivers manual......she said "just give me a minute - I have it right here" more than a minute went by......she said, "sir.....I'm going to transfer you to one of our tech. people" She was very confused as to "comfort" and "sport" as it relates to the suspension and the same terms as they apply to the transmission. Now I'm the phone with the tech. who begins to describe the same system she did.....I do the same interupt....and he says "let me check my system" several minutes go by and he says "I see what you are seeing.........but I can't find any reference to the trans. in that vehicle actually doing that......I am going to have to get in touch with manufacturing reps and will give you a call back" So that's where I'm at now.........I really don't care a whole lot, but you would think someone at MB would want their literature and the website to reflect reality!
Yeah.......sort of like the tech manual on a plane telling you can control the flaps but you find out there is confusion as to how or whether you really can or can't!
Granted, this particular confusion (lack of compentency ) will not result in pain.......
I have a C/S mode in my S Class (also ADSII) and although the suspension is more sophisticated (Active Body Control) it does exactly the same thing. Take off is fast (1st gear) and suspension is firm (S Mode) and slower on take off (2nd gear) and softer (C Mode.)
The GL is just like the 163 ML and doesn;t have the usual Mercedes W/S or C/S transmission mode switch.
Instead the GL with ORP has the LR low range button to shift into another transmission mode, like the 163 ML. On GLs without the ORP the OFFROAD button shifts into the other transmission mode, since it does not have low range.
Now let's wait and see what MBUSA finds out.
Oh, and a car might have to start in 2nd if 1st is a real granny-gear, max-torque-and/or-HP, off-the-light gearing, and also if maybe it's on ice or snow, or some other very slick situation.
But USA 164 MLs dont have ORP and therefore no LR low range button like blittle's GL450 w/ORP, whereas USA 163 MLs all have a low range button.
Another typo on MBs part? I think so. Are they hiring 1st graders to proofread their work?
