Adding Distronic to the GL -- Can it be done
Distronic Plus is a dream at this point but could make it into the GL sometime in the future I guess.
http://www.mbusa.com/models/features...63&class=08_ML
it implies that Distronic PLUS is available on the 2008 ML63
Distronic Plus is not available on any M-B SUV...anywhere.
- sensor
- sensor mounting kit
- grille insert for distronic
- grille (if necessary)
- DTR compatible horns
- Horn mounting fittings
- wiring harness (if orderable)
- coding and installation
- cluster coding
- gateway coding
- ECU coding (if needed)
- ESP must be compatible (usually is)
Assuming that the radiator support is correct for DTR then it should be OK.
Thank you very much for your help.
