rear fog lamp, driver side only?
I was just following my wife in her gl450 on the way to taking the civic to the dealer. I had the front and rear fog lamps on before we swapped cars. It looked like the right rear fog lamp was out but there was no fault warning in the dash. I opened up the rear panel to inspect the bulb. Nothing looked easily accessible but I did find a subwoofer. I read the manual. The manual reads something like, 'rear fog lamp driver side only'. Why would they do this? It makes it look like I'm not maintaining my car properly.
you can install another bulb and it will work. but then you will run into the problem of people in the rear thinking you are braking.
2011 E350 Cabriolet..White and Almond Mocha
If you ever wake up to 5 feet of visibilty in early morning fog at least you have the comfort of knowing it is easier for other drivers to see you... besides that, I wouldn't turn it on.. unless of course you plan on entering the skies!
Thanks guys. I still think it's an odd feature now that the rear window brake light distinguishes braking red lights from other red lights. My Discovery had two factory rear fog lights (probably because rover had too many complaints from people thinking it was really an electrical glitch! lol). I actually don't like using the rear fog lights now. I have this thing about keeping my cars well maintained. I love seeing 10 year old cars looking good as new. I had a 10yr old Range Rover which had assorted minor issues but I atleast kept it cleaned and replaced any bulbs that blew out.
08 GL450
My German cars have had one rear fog light for decades - I like that essential safety feature and use it in inclement weather whenever I can barely see the car in front of me - which means the trailing car can't see ME !. I would avoid double rear fogs - it annoys uninformed drivers who think you are senile and driving with foot on brake pedal or results in inattentive drivers not noticing your brake lights should you use them suddenly.
All my cars - Audi, VW and MB have had only one rear driver's side fog light .
Rear fog lamps
(ECE Regulation 38, SAE J1319) In Europe and other countries adhering to ECE Regulation 48, vehicles must be equipped with one or two bright red "rear fog lamps" (or "fog taillamps"), which are switched on manually by the driver in conditions of poor visibility to enhance vehicle conspicuity from the rear. The allowable range of intensity for a rear fog lamp is 150 to 300 candelas, which is within the range of a U.S. brake lamp. For this reason, many European vehicles imported to the United States have their rear fog lamps wired as brake lamps, since their European-specification brake lamps may not be sufficiently intense to comply with U.S. regulations, and rear fog lamps are not required equipment in the U.S.
Most jurisdictions permit rear fog lamps to be installed either singly or in pairs. If a single rear fog is fitted, most jurisdictions require it to be located at or to the driver's side of the vehicle's centreline — whichever side is the prevailing driver's side in the country in which the vehicle is registered. This is to maximise the sight line of following drivers to the rear fog lamp. If two rear fog lamps are fitted, they must be symmetrical with respect to the vehicle's centreline. Proponents of twin rear fog lamps say two lamps provide vehicle distance information not available from a single lamp. Proponents of the single rear fog lamp say dual rear fog lamps closely mimic the appearance of illuminated brake lamps (which are mandatorily installed in pairs), reducing the conspicuity of the brake lamps' message when the rear fogs are activated. To provide some safeguard against rear fog lamps' masking of brake lamps, ECE R48 requires a separation of at least 10 cm between the closest illuminated edges of any brake lamp and any rear fog lamp.
From Wikipedia: http://en.wikipedia.org/wiki/Automot...Rear_fog_lamps
Rear fog lamps
Rear fog lamps
08 GL450
There ARE cars with factory dual rear fogs in the US market that I've encountered from time to time on the road ( Saab , Volvo ? ,??) .
'07 GL 450, '02 S 80 T6
I have found the rear fog light to be a great tool to use if someone is following too closely at night. I will flash it and the person will typically slow to increase their distance. I don't know if perhaps they think it automatically signals that they are too close..but it has worked for me! I have found it is better that using the finger
![devil](https://mbworld.org/forums/images/smilies/devil.gif)
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
I have found the rear fog light to be a great tool to use if someone is following too closely at night. I will flash it and the person will typically slow to increase their distance. I don't know if perhaps they think it automatically signals that they are too close..but it has worked for me! I have found it is better that using the finger ![devil](https://mbworld.org/forums/images/smilies/devil.gif)
All right, I've only done this once, and it wasn't originally my own idea, but it worked really well. I'd never do it again. What I do these days is either go exactly the speed limit or just let them pass me. Let 'em kill someone else. I have done the "slow rapidly for my turn" routine and actually had a guy in a C-class honk at me like it was my fault he was tailgating me.
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
If I'm feeling particularly childish (and don't worry about risking littering fines) I'll open my sun roof and toss out an empty, un-crushed pop can. They don't know if it's full or empty, but either way it scares the crap out of them without doing any damage.
All right, I've only done this once, and it wasn't originally my own idea, but it worked really well. I'd never do it again. What I do these days is either go exactly the speed limit or just let them pass me. Let 'em kill someone else. I have done the "slow rapidly for my turn" routine and actually had a guy in a C-class honk at me like it was my fault he was tailgating me.![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
If I'm feeling particularly childish (and don't worry about risking littering fines) I'll open my sun roof and toss out an empty, un-crushed pop can. They don't know if it's full or empty, but either way it scares the crap out of them without doing any damage. End of Quote.
"Do this only on a closed course and the driver should be a professional idiot. Do not try this on a public road!"
Whoa Steve...you were really kidding you tried this...right? Reaction by the following driver could have been catastrophic. I don't like tailgaters but there must be a better way...:-)
1 Post
Oh, and I knew the guy and he was the one who told me I should try it. Didn't make him any less peeved at me, but still, indefensible.
Audi has 2 as well, and the Mini Cooper also has 2 rear fog lights but they are low in the spoiler below the bumper......as opposed to being integrated into the tail lights on our new MB. As a new owner....I also thought one was burned out so my wife emailed the dealer...:>)) OOPS! LOL
