Transmission question
The Comfort/Sport button for ADSII is simply the amount of play the airmatic system will allow on the shocks when in a specific mode.
So that is it...no transmission involvement and no starting in 2nd gear in Comfort mode.
This is solid information, not somebody's opinion. I may have more specific details later on and will post when I get it.
http://www.mbusa.com/models/features...50&class=08_GL
Where I read the 550 does indeed feature trans behaviors like the S & E series.
Label me confused too
- Put it in C mode.
- Set the transmission gear limiter to 2nd.
- Give it a little more than 1/4 throttle so the needle jumps to over 2,500 rpm. Any less throttle input and the tranny may upshift before you notice it. I don't know the shift and throttle parameters of the GL550 so I'm not sure if this would help or not.
If it does not upshift then it started out in 2nd. If it does upshift then it started out in 1st and the C/S button does not control the transmission.
As I understand, the 550 has a push button simply labeled C/S?
Or, does it have a 3 position rocker type switch?
My ORP 450 has the rocker style switch, complete with an icon of an air shock in the center.
Instead in the offroaders without the ORP offroad program the "offroad mode switch" shown below selects between the normal onroad transmission characteristic and the off-road transmission characteristic mode.
Some of this is covered in the online manual for the M-Class:
http://www4.mercedes-benz.com/e/cars...56.html#N1BC15
