Thule Atlantis Cargo carrier on factory racks
#51
2007 GL 320 CDI, 2005 M3, 2006 A3
No pics, but we have the 1800 and the 450R crossbars and it works great.
#52
So I was thinking of getting one of the Thule boxes, Atlantis 2100 or 1800 but my 550 doesn't have the cross-bars. I think the chrome ones from MB were $300. Should I see bout getting these or are the Thule bars better?
#53
08 GL450
Our Thule 1800 Atlantis XT not only works/fits well and looks so sleek , but it also fits ( have retailer toss/recycle its shipping box ) inside the GL with middle seats down should you not have time/need to roof mount it after buying it !
#54
Do you have M-B cross-bars or did you buy the Thule stuff to mount it to the roof? If so, which Thule mounting system? Good to know about the ability to fit inside although I'm going to use mine probably 3-4 times per year and will end up mounting each time before the trip because of low garage clearance.
#55
'08 GL450 (P II, ORP, Keyless Go)
#56
The Thule Atlantis racks have a claw system that will grab onto the MB (manufactured by Thule) crossbars. You won't need any additional mounting hardware. Also, if you go to the Thule website, you can get a kit to change the lock core on the carrier, so it uses the same key as the roof rack bar.
#57
2009 GL450, 06 Triumph Speed Triple, 07 Triumph Speedmaster
Just my 2c. Hope it helps.
#58
I was able to get a slightly used OEM chrome set from someone I know who works at the dealer for $150. They look pretty good on there and now it's just a matter of deciding on the Atlantis model to go on top.
#59
https://mbworld.org/forums/gl-class-...cargo-box.html
Just got back from a 2300 mile trip with it on a top and a full load most of the time and I managed 18.9 mpg in mixed driving (mostly hwys in Michigan). Never took the box off. It's fairly low-profile.
#60
Have you considered this one?
#61
You have a 550 or 450? I doubt our 550 could do 19 mixed unless their was a 50-mph tailwind and the whole trip was downhill
I'm using some credit-card points to get this box and have enough for the 1800 or 2100 Atlantis in silver, which matches the truck. I don't have enough points yet for the one you have and want it for our first trip in 2+ weeks.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
![](https://hphotos-snc1.fbcdn.net/hs132.snc1/5651_1214069596142_1360880384_30610670_4661014_n.jpg)
#63
I went with the Boxter which is 1800 and a larger vehicle (the 450; I used to drive a Honda Pilot) and no matter how much more room I have I manage to fill it to capacity.
What you don't see in that pic are the kid's bikes inside the cargo area as well as all my riding gear for my Speed Triple, and a few other things. There always seems to be a birthday party or two celebrated when we are in Mi, usually for my kids, and we end up bringing even more stuff back with us.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#65
I'm going to go with the 2100 because there isn't any reason to get the smaller box right now. I don't have any current plans for something to ride along side the box so the extra width and length won't matter. Like Josey said, you always find a way to use up the extra space so might as well start with more...
#66
08 GL450
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
#67
I hear ya, my daughter's 8 and the handwriting's on the wall so I might as well get the bigger box...
#69
Now that I have the MB cross-bars on I could see why someone might want the wider bars offered by Thule or Yakima. The factory chrome bars I have now look good and can stay up there permanently, but you give up some width if that matters. I think they were recomending the 54" Thule bars and the actual mounting/carrying area is almost that full width. Since the MB bars mount inset of the side rails and curve up at first, you probably have 34 or so inches of "flat" surface vs. 50+ of the others. In my case only putting the 36 wide Thule 2100 up there won't make any difference.
#70
OK, so my Atlantis 2100 has arrived and is still in the box. Due to garage clearance issues, I'm only going to put it on before we go away in 10 days. Does anyone know if the claws on the bottom of the carrier are adjustable fore and aft or I'll have to position the factory bars in a specific place to match claw location? It's been damn cold and hopefully I'll get some time for a trial run before I have to put it on for the trip. TIA
#71
I have a 450 and believe me, I am surprised to have gotten that since I have not been able to get anything over 16.5 previously on the same trip taken twice before. I think it might have to do with the fact that we only had the box on the top instead of the all the other toys we normally take with us. Oh, and if you've ever been through PA on rte 80, you know that it's definitely not downhill all the way ![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#72
OK, so my Atlantis 2100 has arrived and is still in the box. Due to garage clearance issues, I'm only going to put it on before we go away in 10 days. Does anyone know if the claws on the bottom of the carrier are adjustable fore and aft or I'll have to position the factory bars in a specific place to match claw location? It's been damn cold and hopefully I'll get some time for a trial run before I have to put it on for the trip. TIA ![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
Good luck!
Last edited by Josey92; 02-02-2010 at 07:22 PM. Reason: carification on getting the "claws in the middle"
#73
http://www.discountramps.com/smc-600...cle-hauler.htm
I truly hemmed and hawed with this purchase because there are bigger brands out there like Versahaul that looked like it had better fit and finish. This was all based on pics on the web though. Discount ramps also sells Versahaul and Joe Hauler. I decided to get there product because it met all my needs and was more affordable than the others. It turned out to be a great decision cuz the carrier is stable at speed and was within my budget. Granted I have only used it from NYC to Michigan and back but it logged in a lot of miles on that trip carrying the Speed Triple. And I have also used it to pick up my Speedmaster from the far reaches of Long Island with no problems.
As for ease of use, you can load and unload on your own, but I recommend doing it with a buddy. The day I brought home my Speedmaster, I actually dropped it off the carrier when I was unloading. Not huge damage, but it certainly made me feel like a frickin idiot for not asking for any help.
Greatest thing about this setup is that the Airmatic does a great job of minimizing movement that bothers handling. Not completely gone, but enough that even my wife commented that she could barely tell it was back there.
I also recommend getting the Geza Pro-Stretch cover because it minimizes flapping in the wind that will most other covers will suffer from and scratch up your bike. Without the cover, the debris will kick up and may do a number on your paint. The stretch cover will flap a bit because the bike is sideways, but the material does not scratch your paint.
http://www.gezagear.com/
Hope all this info helps whoever is looking for a set-up like this.
I have no ties to either of these vendors so don't think I am getting any kick-back for mentioning them.
Let me know if you have any other question.
#74
