3 Zone Climate Control Package
1 Post
13 Lunar Blue GL550, 06 Imola Red BMW X5 4.8is, 04 Gold Honda Ody
Does anyone know if the 3 Zone Climate Control Package which costs $990 is the same on that is included in the PII package?
1 Post
Thanks. I found it strange that a dealer had around 3 GL450's that had both the PII and 3Zone packages so basically they are charging $990 extra for an included option. Even on the build your own site it allows you to add both.
It is unlikely they are trying to charge you twice. (I hope)
The Netstar printout has a left hand column titled "accessory code". These are chargable items. It may have the item 3-Z-Climate number (I think it is 581) listed in the description separately but it is probably included with other bundled items under an accessory code of P02.
If the option isn't bundled, but is charged as a line item, then 581 will show up in the accessory code column.
Clearly I have spent too much time looking at GL's this past couple of weeks.
'07 GL 450, '02 S 80 T6
