Is driver window supposed to close with one touch?
Old Dec 14, 2008 | 11:06 PM
ddcha's Avatar
2022 E53 SG
My driver window opens with one touch (opens all the way down), but not when I'm trying to close it. All other windows open and close with one touch. Couldn't find help in the owners' manual. Anyone have this issue?
Old Dec 14, 2008 | 11:24 PM
Comfy_Couch's Avatar
2008 GL 320 CDI
It should open and close with one touch. Take it to the dealer.
Old Dec 14, 2008 | 11:51 PM
oknish's Avatar
'07 GL 450, '02 S 80 T6
Like comfy says, it should close with one touch. But you do have to push the button all the way, past the resistance point.
Old Dec 15, 2008 | 03:37 PM
lkchris's Avatar
'10 CL550, '12 GL550
Mine stopped one time IIRC after some service work.
This is something the service advisor can usually do without help from a mechanic and this was the case and I was on my way in 2 minutes.
Old Dec 15, 2008 | 03:53 PM
blittle's Avatar
2013 GL450 (traded for 2015 Escalade), 2012 Corvette, 2014 Ford Fusion, Previous: 2007 GL450, 2011
Mine quit working for one day and then magically syartedworking fine the next day.......that was a couple months ago.........no problems since!
Old Dec 15, 2008 | 04:41 PM
ddcha's Avatar
2022 E53 SG
thanks folks. damn gremlins strike again...
Old Dec 15, 2008 | 04:42 PM
Blk04cobra1's Avatar
2002 S430, 2004 Cobra, 2004 Tahoe
Try this...turn the car on...press and hold the up button til it closes all the way, then immediately press and hold the down button til it goes all the way down...try this twice, then cut the car off, count to 10 and turn the car back on...if it does not work after the first sequence, try it one more time...this should reset your window functions
Old Dec 15, 2008 | 04:47 PM
ddcha's Avatar
2022 E53 SG
Holy master technician secrets batman! I will try this tonight. Thanks! (or curses if you're pulling my leg).
Old Dec 15, 2008 | 10:11 PM
JimBarnhart's Avatar
2015 Ram 2500, former 2013 GL350, 2007 GL450
Same problem - once within 30 days after I bought. Haven't had the problem again....gremlin.
Old Dec 16, 2008 | 08:54 AM
Lucky13's Avatar
2004 C230SS & 2007 GL450
Jim,
I had the same issue, but the next time in the car it was fine. No repeats since then. Gremlins, or BMW beaming microwave signals into the car to get us to switch!
Old Dec 16, 2008 | 04:00 PM
Well, did my suggestion work for you this morning?
Old Dec 23, 2008 | 10:12 PM
robalo220's Avatar
2014 Black SLK 55 AMG, Black 2015 GL 550, 2011 Blue GLK 350
My window did that exact thing once. I ran the window all the way up by holding the button until the window stopped but I continued to hold the button in the up position for a few seconds. It has worked fine since.
Give it a try and see if it works on yours.
