cargo box and garage door opening
2010 C63 / 2009 GL450
Reviewed the threads re: cargo boxes. Do you guys keep the car outside when the cargo box is attached or do you not have any trouble pulling into the garage with the added height? I have standard height garage door and wondering if I have to pull the box off every time I come back from weekend ski trip. Also, has anyone used newer "low profile boxes by Yakima or Thule?" Comments and suggestions appreciated!!
1 Post
2004 RX330, 2008 Scion xB, 2001 Honda Insight Hybrid, 2010 Toyot Prius v ATP
Your mileage may vary.
'06 A6 & '08 GL550
We have the MB OEM cargo box and it fits fine through our standard height garage door. Measure the height of you garage door opening and compare it to your vehicle, then follow STP's instructions and you'll be good to go.
2013 Land Cruiser, 2007 GL450 [SOLD], 2007 Toyota Tundra Double Cab 4x4 Limited, 2009 Corolla LE
Typical garage clearance hieght is 7 feet and some custom homes have 8 feet or more. Measure yours to be sure b4 u enter into garage with cargo box attached.
You do realize that garage openings are standard right? It is a very good question, given that spec heights are all published.
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
However, we can't assume that the OP's conception of "standard" is indeed, an "industry standard". Maybe in his neighborhood, they all have 6-1/2' doors and he thinks that is standard. Actual measurements are the only thing that works. Plus, how do we know what "box" he has - as it sounds like he already purchased one, from the way it was worded. I have a cargo box and a 7' door and there is no way it will clear.
But the best answer is/was "Just measure it your gosh darned self".
